voltage issue, need help bad!!!!!!
Old Nov 25, 2007 | 11:22 PM
SSPOWER's Avatar
Default voltage issue, need help bad!!!!!!
It is driving nuts trying to figure out where my problem is coming from. I just got a brand new red top optima battery and a 200 amp powermaster alternator and installed it. My voltage came up to 14-14.5 then I took it for a test drive because I always want to be sure everything is alright. Sure enough after a couple laps in the neighborhood the voltage started to drop into the red everytime I wasn't on the gas. Please help I can't afford to replace much more.
Old Nov 26, 2007 | 08:12 AM
02StanGT's Avatar
Default RE: voltage issue, need help bad!!!!!!
Everything hooked up correctly and secure? Loose wires could be the culprit of your undercharging. Also improper belt routing, no belt, little to no belt tension could be key.
Old Nov 26, 2007 | 10:50 AM
MassholeLT1's Avatar
Also check for a bad ground somewhere
Old Nov 26, 2007 | 04:55 PM
SSPOWER's Avatar
It is definately not a belt issue. I have the comp cams torque adjustable belt tensioner, which is great. I think M*******LT1 hit it on the head. I drove to work and when I came back from my route and got in my car to go home the car wouldn't start. Thanks for the comments and if anyone else has any ideas that would be helpful.
audubontrace
May 4, 2015 10:36 PM
onebad88
Sep 18, 2012 11:06 AM
Jerry95lt1
May 3, 2011 05:59 PM
Masospaghetti
Sep 20, 2009 01:41 AM
squisher
Feb 9, 2007 09:42 AM
