computer issues? on an '84
Old May 30, 2008 | 03:10 PM
pdubz28's Avatar
Default computer issues? on an '84
well i have a 1984 z28 h.o. camaro and it has the l69 engine. i got from my uncle for free because it threw the timing chain and need new pushrods, ect..., so dad and i rebuilt the engine andgot it tuned up pretty good. then about a year later (april 2008) i had a custom interior put in, now there is nothing really that needs to be done....... until about a week after we got it, itstarted having starting issues noelectricity for example, nodome light or headlights so we then put in a new battery and starter, that seem to fix the problem. then maybe another week or two later it starts bogging down when its cold and wontidle until its warm about 150 degrees. but also when i cruise at about 1250 rpm @35 mph (even when warm)sometimesit will shift to overdrive and then back down continuously. so after that the local mechanic said a new computer should fix it but it didnt help at all, exept my mixture solenoid dosent cycle all the time now like it used to.also just the other night the choke light came on when the engine was warm, for no reason. so it took the air cleaner of to see if it was closed but the choke was wide open. any feed back or any thoughts i will greatlyapreciate. the mechanic is having trouble pin point why it is bogging down so i hope u guys can.
Thanks,
Patrick
P.S. also i couldn't get the fan to turn on during engine breaking about a year ago so we wiredit to run all the time.
Old May 30, 2008 | 04:15 PM
MadMikeZ28's Avatar
Default RE: computer issues? on an '84
First off don't go into full panic mode and post all over. One post is plenty in this forum. People will see it.
Second
Check the charging system. A good mechanic would know that on older carbed cars the choke runs off the alternator so it will only get power while its running. A problem in the charging system will cause a choke light to come on.
Old May 31, 2008 | 05:25 PM
pdubz28's Avatar
sorry of course i am new to this forum. but ill see what our local mechanic thinks.
Thanks,
pat
Old May 31, 2008 | 07:01 PM
MadMikeZ28's Avatar
Its ok. I will let you live this time
Christophern
Nov 29, 2010 11:04 PM
bezerker
Aug 14, 2010 08:02 AM
pdubz28
Jun 2, 2008 06:05 PM
