Choke Light stays on
Old May 18, 2007 | 05:30 PM
Lackey's Avatar
Default Choke Light stays on
Hi All,
I've got a 86 IROC Z28 carb V8. The choke like stays on so I suspect I have a stuck choke. Is this something that can be fixed or should the choke just be replaced. Anyone has a manual or scan of how to replace if needed? Appreciate the help in advance! Looking forward to running her all summer.
Old May 22, 2007 | 01:01 AM
ohiocopper12's Avatar
Default RE: Choke Light stays on
have you checked to make sure that you have power to the choke? that would be the first place to check. thinking all basic manuals you get at auto zone have the 'how to' section for it. not a lot of posts in this sections, may want to put it under 3rd generation in the regular post section. sorry, not a lot of help.
Old May 22, 2007 | 03:05 AM
MadMikeZ28's Avatar
It could be an alternator problem. The choke gets its power from the alternator while its running. That way if the key is on and the engine is not running the choke won't heat and open. Also there is a relay on the convienece center. That should be under the dash above your right foot. You just about have to have your head under the dash looking straight up to see it. The key buzzer is there also so if it is working follow the sound.
Old May 23, 2007 | 01:25 AM
most interesting ref the alternator. didn't know that. my choke is messing up some as well. i know my alternator is bad as the lights like to flicker. perhaps....me changing my alternator will fix my choke. always good to read other posts. never know what you'll find. thanks again mike.
Old May 25, 2007 | 08:28 AM
berlinettalover's Avatar
I had the same issue take some electrical cleaner and spray the damn connector at the carb....Mine was all junked up and as soon as i cleaned it no more light....
RS67RS
Apr 27, 2015 05:48 AM
Craig Ferguson
Apr 15, 2013 12:49 AM
shaione
Feb 27, 2013 07:15 PM
shaione
Nov 19, 2012 10:27 AM
hosehead
Sep 1, 2006 03:08 AM
