abs inop light stays on
Old Feb 26, 2013 | 10:20 PM
shaione's Avatar
Default abs inop light stays on
anyone know what wheels sensor might be causing this to stay on? I went through the car wash the other day and the brake light traction control light was blinking like crazy..the funny thing is it always happens when the water shoots at the front end of my car, Im trying to narrow whats causing the abs inop light to stay on
Old Feb 27, 2013 | 12:18 AM
NoSoupForYou83's Avatar
Mine stays on all the time. And the brake light. Same thing in my 92 cavalier. Must be a Chevy thing.
Old Feb 27, 2013 | 12:40 AM
Since you pinpointed the reaction to the front, start looking there. It appears as though you may have a split/cracked wire, or a connector with a bad seal, where water is getting in and causing a short. Check the condition of the ABS wires, and unplug any of the connectors, clean and dry them, and put back together after giving them a dab of dielectric grease.
Old Feb 27, 2013 | 07:14 AM
jkeaton's Avatar
There is one at each front wheel and another one in the differential.
Old Feb 27, 2013 | 06:31 PM
shaione's Avatar
where are the abs wires at to check?
Old Feb 27, 2013 | 07:15 PM
front wheel sensor wire harness leads are a common fail point. they go from the wheel hub to the fender area and take the most abuse.
RS67RS
Apr 27, 2015 05:48 AM
Craig Ferguson
Apr 15, 2013 12:49 AM
shaione
Nov 19, 2012 10:27 AM
johnnie72
Mar 4, 2012 07:50 PM
hosehead
Sep 1, 2006 03:08 AM
