CAR STARTS...STUTTERS...DIES OUT PIG RICH..
Old Sep 25, 2007 | 06:57 PM
tonyvlx's Avatar
Default CAR STARTS...STUTTERS...DIES OUT PIG RICH..
88 IROC Z28 350... REPLACED ALL FUEL LINES AND FILTER. STARTED UP FINE AND RAN. TRIED TO START CAR THE NEXT DAY, STARTED BUT STUTTERD AND DIED. WHEN ON WHILE GIVING THE CAR GAS, IT SEEMED AS IF IT WAS CHOKING AND THE EXHAUST IS RUNNING REALLY RICH.
ANY INFO OR HELP WOULD BE GREATLY APPRECIATED. THANK YOU.
BARRY O'RIELY
Old Mar 20, 2008 | 07:06 PM
Camaro4life90's Avatar
Default RE: CAR STARTS...STUTTERS...DIES OUT PIG RICH..
Hi I own a 90 camaro v6 but mine was doin the same thatyour's is doin. I took it to a mechanic and they said Distributor is gone the pick coil wasn't responding so try checking your's I will buy a new one soon and put it in and let you know if thats the problem with mine.
Old Mar 23, 2008 | 02:10 PM
carguy_z28's Avatar
Have you checked your PCV valves lately? Supposed to be changed every 3 oil changes or so... they can cause this. Its a 3 dollar part and can cause a lot of stress if not maintained.
Old Apr 4, 2008 | 10:52 AM
jamez00's Avatar
Most common problems: the Catalic converter is plugged, or not enough fuel pressure (to check-turn key to ON position, you'll hear the fuel pump priming for 3-5 seconds, once it stops, unscrew the valve cap from the fuel rail (located on the rear pass. side of engine) andusing a reg. screwdriverpush down on the valve just like you would do to let air out of a tire, gas should spray up and hit the hood, if it don't or if it piddles out,your fuel pump is bad. TPI's have 45psi of pressure,which is needed to feed through the injector's. If that's ok then it could be the Mass Air Flow sensor.check to see if the "service engine soon" lightstays on when it does try to run, if so you'll need to get check to service code(s) it has to see wantsthe problem sensor wise.
HappySalesman
LS Series Tech
Jul 18, 2014 12:10 AM
chip655
May 18, 2011 05:46 PM
tanker425
Sep 6, 2008 10:35 PM
jonburgess
82-92 V6 Tech
May 16, 2008 03:29 PM
ducatiguy
Oct 15, 2005 12:36 AM
