bypass emissions?
Old Aug 20, 2008 | 07:16 PM
nabisco's Avatar
Default bypass emissions?
my brother has a irock that when the new motor was put in it was all spliced and many problems, the previous owner hacked it all up and they disconnected the emissions, since they arent hooked up can i just put regular headers on the car and is there anything elses that will need to be done, we just want the 350 to run good with no extra crap to worry about
thanks
Old Aug 25, 2008 | 05:02 PM
slick84z28's Avatar
Default RE: bypass emissions?
i have a 84 z28 that i put a 350 in.i did not hook up any emissions on the new motor.i went with a set of shorty hedman headers. the only the i had to modify is the y-pipe.the y-pipe had to be remade to work with headers even though they were "direct fit".the headers did not have the air lines or smog line on them.is you'r 350 tpi or carb and is the computer still hooked up? this will probaly made a difference on how much you can unhook or leave unhooked.
Old Aug 25, 2008 | 06:57 PM
MadMikeZ28's Avatar
You might want to weld a bung into the headers so you can use the O2 sensor. You will need that if it still has its TPI. The air injection tubes you can do without as long as there is no inspection.
87 camaro z28
Jan 22, 2013 04:46 PM
MI_camaro_98
May 7, 2008 09:57 PM
herestolife1000
Apr 20, 2008 02:08 AM
rancho2940
Aug 5, 2007 03:13 PM
parker987654321
82-92 V8 Tech
Jul 17, 2007 04:59 PM
