91 RS rear end swap questions
Old Feb 10, 2008 | 02:45 PM
91rsvortec's Avatar
Default 91 RS rear end swap questions
I want to replace the low gear non posi rear end in my 91 RS. How can one tell the difference between a posi and the rear end thats in there now? Any suggestions on which rear end to look for that will bolt right in? Maybe justa drum to disk upgrade. Thanks
Old Feb 10, 2008 | 03:23 PM
350rs's Avatar
March 2008 ROTM
Default RE: 91 RS rear end swap questions
look on your RPO sticker for G80, thats the limited slip code. if you want one that will bolt right in. look for one out of another third gen. The 9bolt is a good choice for a direct fit swap. but if you want to spend a little money, you can get the ford 9" and swap out the mounts from the rear in your RS already to the 9". But unless your a GOOD WELDER and are able to make the mounts in the right spot, bring it to somebody to have it done. I wouldnt think it to cost TOO much to do, but it wont be super cheap. Good luck
Old Feb 24, 2008 | 01:19 PM
hlmoose's Avatar
summit has direct bolt in kits you can get here. http://store.summitracing.com/egnsea...4294925024+115
and I might also check jegs and spohn preformance. and the breaks you can just plane out buy them but there not cheap.
chevyguy912
82-92 V8 Tech
Jan 5, 2012 11:56 AM
Senshi09
Dec 26, 2011 06:21 PM
project blackjack
82-92 V8 Tech
10
Jan 26, 2010 09:39 AM
slickscamaro
Jun 7, 2009 09:01 PM
libertyforall1776
Mar 17, 2008 03:42 PM
