86 z28 auto!hovering between'gears'??
Old Mar 21, 2011 | 08:27 AM
Amy Z28's Avatar
Default 86 z28 auto!hovering between'gears'??
1986 IROC-Z28 5.0L TPI.
Hey, ok cars been running sweet untill last wee 'service engine soon' light appeared, so i did a Error Code check and it flashed up 15 (low temp indicated at engine coolant temp sensor) The heater matrix(core) blew 2summers ago and was by passed (dont know if this has anything to do with it)?? Anyhoo, worse i took it a drive and as i get to about 40/50mph in Drive,it hovers between 3rd and 4th with revs at about 3000rpm, it wont settle into a lower gear untill i put it into Overdrive? please help! the gearbox and eng.oil is fine???thanks for looking, Amy x
Old Mar 21, 2011 | 08:40 AM
First, fix the coolant temp sensor problem. As it is, the system doesn't know whether or not the engine is up to running temperature, and your computer may not be keeping the air/fuel mix where it wants to be. Bypassing the heater core has no effect on how the engine heats up or performs.
Old Mar 21, 2011 | 08:47 AM
Amy Z28's Avatar
Default yay a reply!
thanks what would be the name of the part i need exactly to fix this and ill get it ordered now also can u recommend a gear.box fluid and engine oil for my car as going to give it a change. cheers.
rayistfaaku
Jan 21, 2011 07:32 AM
My01Z28
LS Series Tech
Mar 18, 2008 02:39 PM
khart1684
Aug 17, 2007 10:23 PM
onefastlt1
Jun 21, 2007 07:23 AM
