91 Auto trans, all gears are nuetral...help
Old Aug 17, 2007 | 03:30 PM
khart1684's Avatar
Default 91 Auto trans, all gears are nuetral...help
91 RS,700-R4. I replaced the torque converter and the pump seals awhile back in my auto class(college). Drove it home(about 13miles) and everything was just fine other than the shift point from 1st to 2nd seemed to be longer than it should be. Later that day I took it up the road to see if it shift properly when punching the gas pedal. FRom a stop, I gunned it, I don't even think it shifted into 2nd, it just buried the RPM needle and stalled out. Quickly started it back up and it just coasted in drive as if it was in neutral. Luckily it was just up the road. Had to tow rope it back to the house. Now all gears are like Neutral, but when moving the shifter you can hear the slight change in the RPM's. I have no idea as to whats wrong with the transmission...Hopping you can point me in the right direction to fixing this problem.
Old Aug 17, 2007 | 06:26 PM
Default RE: 91 Auto trans, all gears are nuetral...help
I would suspect the last thing you did. Broken torque converter or bad shaft seal. In any event, it sounds like you should take the car back to school and redo the transmission.
Old Aug 17, 2007 | 06:32 PM
Iowa87CamaroRS's Avatar
Welcome!
damn man, why would you do that to a beautiful car? lol Anyways yeah taking it back to school to rebuild the transmission is the best
Old Aug 17, 2007 | 10:23 PM
khart1684's Avatar
rebuild...nothings wrong with the clutches, I'm not all that familliar with Auto tran's but I wanna what thing/things are the most likley to have broken. The torque converter was brand new when I left the auto shop, it doesn't leak fluid @ all.I droped the pan @ the time and fluid was just as red coming out as it was when I poured it in. So that means that nothing "major"has faild, right?[&:]
olered
Nov 13, 2011 08:52 PM
Amy Z28
82-92 V8 Tech
Mar 21, 2011 08:47 AM
MaVeN
Aug 31, 2010 01:17 AM
My01Z28
LS Series Tech
Mar 18, 2008 02:39 PM
toml14
Dec 28, 2006 12:33 AM
