'84 Z28 ... is the clutch (stock) hydraulic or no?
I don't know that I've ever dealt with a hydraulic clutch ... does the stock 1984 Z28 have a hydraulic clutch?
How can I tell the difference?
Thank you in advance.
look at the trans if its hydraulic there will be a slave cylinder to push the clutch fork if its manual than there will be a cable going to the driverside... also you can look in the engine compartment if you find a little reservoir thats for a hydraulic clutch
Where would the reservoir be exactly?
