700r4 trans help
Old Dec 22, 2009 | 11:46 PM
nebraska83Z28's Avatar
Default 700r4 trans help
Can someone please explain to me why my 700r4 has a plug and a wiring harness, and what controls it? What do the wires go to? My 83z has a new 305 that basicly bypasses the ecm, does the ecm control the trans as well? What can I do (if any thing) to insure that my trans is operateing correctly?
THANKS
Old Dec 23, 2009 | 01:33 AM
The wiring is for the lockup feature of the torque converter.
In overdrive, the ECM trips a solenoid in the trans that activates the control valve which allows fluid to be pumped forward to put pressure on the lockup clutch inside the torque converter.
So to keep the lockup operational, which you do want to keep, you need to install an aftermarket lockup control like one of these: http://www.summitracing.com/search/?...20lockup&dds=1
Also make sure you adjust your Throttle Valve (TV) cable properly. That controls shift points and internal fluid pressure. A misadjustment can cause off-shifts, and could also eventually burn up the trans.
Aeonian
Nov 19, 2011 09:41 PM
olered
Nov 13, 2011 08:52 PM
libertyforall1776
Sep 13, 2011 12:28 PM
kelleyperformance
82-92 V8 Tech
Sep 7, 2010 07:20 PM
jml317
82-92 V8 Tech
Sep 14, 2007 04:27 PM
