4l80e elect. connector question
Hello, I tried posting this question at a chevy/trk forum but got no replies and I need help kind of quick so I'd like to try it here because I always get answers pretty quick.
Working on a 93 C2500 2wd pick up with a 4L80E auto transmission. I can't figure out how to remove the main wire harness connector going to the transmissions driver side. It has about 10 wires going to it and has a little plastic piece sticking out from the center of the connector. I tried twisting and pulling but I can't seem to disconnect it. Please help.
Thanks
Mike
Thanks
Mike
Hey Madmike and Rat, just a quick up date. I found out that mine is an early 92 connector which has a T25 torx bit deep in the center of the 12 pin connector. The later type has the 2 outside flat clip. I had alot of road crap around the harness so I didn't see the screw head at first. Thanks again for the response.
stox58
02-29-2016 08:16 PM
Flex
10-02-2010 01:42 PM
