Stalling 3.1
Old Oct 10, 2014 | 10:15 PM
lunyty's Avatar
Default Stalling 3.1
92 RS stalling when letting off and going under 1000 rpm,3.1 recent plugs-wires 30,000 ago,,any temp,,no codes, no CEL,,,,stumped runs fine,until slowing for traffic ,stop etc..rpm drops then dies,,,idles bad HELP
Old Oct 11, 2014 | 09:26 AM
Fuel pump, fuel pressure regulator, and idle air control valve are the first things that come to mind. Check your fuel pressure (your local Autozone may have a gauge on loan) at the fuel rail, and see where pressure is when you first prime the pump (not start), when idling, under acceleration, and how long pressure holds after you shut the engine off. Also pull the vacuum hose off of the pressure regulator and see if any fuel comes out. If it does, the diaphragm inside is bad and you need a new regulator. Then come back with the findings.
Old Oct 12, 2014 | 09:21 AM
blackz87's Avatar
I would go with the Idle air control valve (IAC).
91RS305TBI
82-92 V8 Tech
21
Sep 19, 2012 05:04 PM
Growler75
Nov 11, 2011 12:15 PM
ohbhave
Aug 23, 2010 08:57 AM
my93z
Dec 5, 2009 03:05 PM
ilovemycamaro
Aug 10, 2006 10:48 PM
