Ignition coil
Old Sep 20, 2007 | 12:06 PM
mattman's Avatar
Default Ignition coil
I just bought a 1987 camaro with a 2.8 and its not getting any fire so I bought a new coil and plugged it up and it is still not firing. Does any one know the wiring diagram on this car or know some things I could try to fix it? Thanks Matt
Old Sep 20, 2007 | 07:17 PM
Default RE: Ignition coil
Assuming your new coil is good then:
1) Turn ignition key toON & make sure there is 12 Volts at the + terminal of he coil (pink wire)
2) Check ignition module (remove & take to a shop)
3) Check pick up coil
4) Get a service manual
KawasakiJ14
Jun 25, 2009 03:49 PM
logansz28
Sep 14, 2008 10:40 AM
aightball87
Jul 3, 2008 03:20 PM
rwing7486
Jun 2, 2008 03:39 PM
