got ignition probloms
Old Dec 22, 2008 | 11:32 PM
mattie08's Avatar
Default got ignition probloms
alright i am new here but any ways i have a 92 with a 3.1 v6 auto sad i know but my problem is when i turn my key to start the car it just clicks the starter that is but i have replaced the ignition switch and the battery termanals and the battery and the starter is good had it tested three times at oreillys and replaced the ground cable and still the same problem got any suggestions
Old Dec 23, 2008 | 06:47 AM
Default RE: got ignition probloms
Not being able to crank the engine is not a an ignition problem. The clicking is the sound of the starter solenoid energizing. When the solenoid energizes it is supposed to feed battery power to the starter motor and move the starter gear into contact with the flywheel gear. Assuming all battery and ground connections are good, it is possible that the solenoid is bad, starter drive is bad, starter is jammed or not shimmed properly,engine seized, the starter is actually bad, or battery not fully charged.
Old Dec 23, 2008 | 09:50 AM
n8_camaro_92's Avatar
try jumping it to see if the battery is dead... if it strts then let it run a while and shut it off and try again... if it wont start i suggest a new battery
Old Dec 23, 2008 | 11:25 AM
mattie08's Avatar
like i said the starter is good took it to oriellys and tested it three times and not the engine is not seized
Old Dec 23, 2008 | 11:46 AM
Saint_Ali's Avatar
it still could be the solenoid is bad, when they bench test it bypasses the solenoid and just tests the starter motor itself,try jumping the starter and see if that works
jeffchairs
Jun 4, 2014 04:12 PM
Chevynutz
Jan 22, 2012 07:52 PM
dogdog130
Sep 11, 2011 01:12 PM
93camaroz28
Jan 8, 2008 10:58 PM
carguylt1
Mar 22, 2007 09:47 PM
