Can't get my 92 camaro to trun on.
If you said that you've tried everything, what exactly did you try? Does it cank? If it does, does it have proper fuel pressure or does it have spark? Can you be more specific?
when you turn the key, does it make a clicking sound, or is it just nothing??? if you don't hear anything when trying to start it, it could possibly be the start solenoid has gone bad. i had the exact same problem with my '90.
take a screw driver and connect both poles on the solenoid (make sure the key is on). it should fire up this way, if not then you've got a wiring issue (not uncommon with 3rd gens).
