ECU/Misfire Problem help
Old Jan 4, 2010 | 03:32 PM
Originally Posted by thegad
Yea i went through all of the fuses under the hood in that fuse box, everything looked good. I havnt been back to advanced to have them hook it up sence then. I just got back from a drive to FL for the weekend. It did great. didnt miss any. Check engine light came on and went off a few times but other than that it seemed to do well.... im at a loss.
Time to go on an Easter egg hunt!
Open the driver side door. Look at the end of your dash and you'll see a cover with a **** that you can turn. I'll give you 100 guesses what's hiding under that cover, but I bet you'll get it in one guess!
Old Jan 4, 2010 | 10:42 PM
thegad's Avatar
AN EASTER EGG IN MY CAR!!!!
Old Jan 4, 2010 | 10:47 PM
Nope, guess again. Hint....they are colorful and can break (mostly from the inside).
Old Jan 5, 2010 | 09:17 AM
thegad's Avatar
Ok found a rotten egg. just so happens its the Cig/assy one haaa.
So now this leads to another question. Is there something wrong that burns this fuse up or does it just happen from time to time and i should replace the fuse and forget about it?
Old Jan 5, 2010 | 10:55 AM
Well, whattaya know?
Someone along the way could have plugged something into the socket, and maybe got the plug crooked and it shorted out? Or a foil gum wrapper got in there and shorted? Or someone used the cigarette lighter often (the lighter is a dead short coil). Or high humidity, an overloaded device, sticking your wet finger in the socket "just because". Could have been anything. After you replace the fuse, keep an eye on it.
Old Jan 6, 2010 | 08:12 AM
thegad's Avatar
Alright thanks for all the help. I went and got the check engine light read. Bad EGR valve, will that cause the misfire?
Old Jan 6, 2010 | 09:05 AM
Yes it can, but the EGR valve itself may or may not be the problem. Before thinking about replacing the EGR valve, you can try removing and cleaning it. Yours could be carboned up and crusty to where the pintle seat isn't closing all the way. Also check your electrical connections and vacuum hoses to the EGR. And since the EGR valve recirculates exhaust gases, even having too much exhaust backpressure (a restricted cat converter) can cause EGR issues.
Pidi
LS Series Tech
Mar 16, 2012 02:05 PM
BIGMIKE
Aug 9, 2009 07:22 PM
dangerjakeray
Jun 2, 2009 12:32 PM
Rmlink
Apr 14, 2009 07:56 PM
hrankarl
May 11, 2007 04:44 PM
