does this work??
Old Sep 18, 2007 | 10:34 AM
littleredcar's Avatar
Default does this work??
I own an 85 camaro that has a 2.8 in it. i bought a 1978 350 with 4 bolt mains and am in the process of prepping it for a swap on my car. bolted up to my 2.8 is a 5 speed tranny. i dont have the means to measure my bellhousing or a bellhousing at all for the 2.8 and was wondering if my transmission will bolt up to my 350??
Old Sep 18, 2007 | 03:59 PM
1990CamaroRS's Avatar
Fancy Sparkle
Default RE: does this work??
the 2.8 is a 60 degree motor, the 350 is a 90 degree. you're going to need a new bellhousing, plain and simple
Old Sep 20, 2007 | 08:42 AM
What would you say to use??
Old Sep 20, 2007 | 10:23 PM
sewerrat's Avatar
You need to find a T5 bellhousing from a small block chevy. You can check your local salvage yards or even ebay. Just make sure it's from an 82-92. That way the trans will be clocked in the correct position. You'll also need a special clutch disc that has the 14 spline hub with the larger friction disc. Better yet try getting a complete T5 trans from a V8.
Old Sep 21, 2007 | 10:13 AM
did they put thet5 tranny on to the 305 engine??? and out of not knowing much about transmissions, are t5's manual?
Old Sep 22, 2007 | 03:38 AM
sewerrat's Avatar
Yes and yes.
383 Coupe Car
Mar 2, 2010 09:04 PM
Socom
Feb 16, 2010 12:46 AM
thatcamaro
Jan 25, 2010 04:47 PM
Z28Reggie
Aug 12, 2008 06:02 PM
92 RS in training
Jun 13, 2007 11:58 PM
