building a 84 v8 camaro
Old Jun 19, 2011 | 10:02 AM
stealthwizard89's Avatar
Smile building a 84 v8 camaro
ok i was told that i need a fbody transmission cause the bell housing so i was told only a fbody tranny would fit type of tranny is700r4 i have a t5 out of a v6 but i dont think it will bolt up to a v8
Old Jun 19, 2011 | 10:05 AM
and if other 700r4 out of other cars fit what cars have a 700r4 thats compatible for a 84 350 camaro
Old Jun 19, 2011 | 11:33 AM
djs383's Avatar
the T5 from the V6 is a no go....what type of build are you doing, low dollar, or high(er) dollar? That will make a difference. You'll need a pre VSS 700R4 for your application. They are a good trans and if built correctly will take a lot of HP and Torque. Those trans are a dime a dozen, but will most likely need a full rebuild.
Old Jun 19, 2011 | 11:55 AM
the block is a 75 350 truck block the pistons are remanufactured from that block new rings and bearings lunati voodoo cam world alum heads lunati blue roller rockers weiand xcelerator intake holley 750
richarddda
Nov 30, 2010 09:43 PM
z69
67-69 V8 Tech
Oct 15, 2010 12:29 PM
CamaroDude95
82-92 V6 Tech
Jul 17, 2009 12:53 PM
CamaroDude95
Jul 15, 2009 07:22 PM
sanj195
Oct 31, 2006 01:25 PM
