Acceleration weird light
Old Jan 29, 2009 | 08:24 AM
85DriftMaro's Avatar
Default Acceleration weird light
so see if you guys know this one. so the other day i got stuck in the snow so i was trying in reverse then it caught the grip and shook the car violently and then a plug wire came loose but no other problems. then the next day driving to school when i accelerated (Full Throttle) the overheating light will flicker it will be a light flicker with not a lot of throttle. but when i really give it a little somethin then it will go solid. even on the freeway in fith gear if i floor it then it will flicker. By the way its an 85 Camaro Berlinetta Sport Coupe v6 2.8 MPFI
Old Jan 29, 2009 | 09:11 AM
Are you sure it si not the check engine light that is going on? What is the temp gage indicating?
Old Jan 29, 2009 | 04:22 PM
oh sorry i forgot to mention the battery, oil pressure, and overheating gauges are not gauges they are just lights if it is a problem than they will light up i also dont have a tach its just a big fuel gauge
1bad
May 28, 2014 05:32 PM
Rent
Apr 22, 2013 11:08 PM
husker_camaro95
Feb 24, 2011 08:42 AM
baradonai
Nov 12, 2010 10:54 PM
EDGE
Apr 5, 2008 07:59 PM
