91 rs 3.1 fuel pump
Old Nov 19, 2007 | 02:40 PM
blackheart2358's Avatar
Default 91 rs 3.1 fuel pump
I have a 91 rs camaro v6 3.1
so last night when getting ready to go home the car started I backed out of my parking spot and as I pushed in the clutch to shift into first the car died and wouldn't restart , engine turns just fine (proper speed )
I noticed that I don't hear the fuel pump winding up so I think thats the problem
I had replaced the pump aprox 3 years ago so I'm surprised to have another one go bad this fast
looking at a couple posts here they talk about relays under the hood
I can't find any mention of these type of relays in my auto manual
does a 91 rs 3.1 have under hood relays and where would they be located
also when trying to use a wire to test codes I only get the code 12 which I understand signifies that it is in a diagnostic mode . now it dosen't reveal any codes it only flashes the 12 code continuously
is there a good way to test the ecm computer to see if the problem lies there
any help and advice would be appreciated
I realy don't want to have to pull the tank again only to find the problem is something else
thanks , John
Old Nov 29, 2007 | 05:40 PM
legacyin07's Avatar
Default RE: 91 rs 3.1 fuel pump
When i tested my code I just took a plain wire any wire will do and plug them into bank A and bank C I think dont quote me its either bank A, C Or B you have to jump the 2 together it will flash cose 12 then it will flash you code. If it is the fuel pump I have a very easy way to replace it I just did mine
Old Mar 20, 2008 | 04:39 AM
94CamaroSFI's Avatar
the car is 17 years old.. No one has ever changed the pump.. You're looking at 85 bucks max. CHANGE IT
Old Mar 20, 2008 | 01:17 PM
age84's Avatar
March '09 ROTM
Hes said he replaced the pump three years ago. did you check the fuse under the dash
jon_uscg2001
Aug 25, 2011 12:23 AM
nehidustin
Jun 28, 2010 07:30 PM
carmodder
82-92 V8 Tech
Jun 23, 2008 12:50 PM
BlueKitsune
Oct 5, 2007 07:54 PM
johnson3034
May 25, 2007 09:35 PM
