What transmissions would you recomend
Old Jan 21, 2006 | 08:56 PM
Sleeper91's Avatar
Default What transmissions would you recomend
I have a 91 RS, i took out the 305 and dropped a 350 .30 over that is running close to 350-360 hp, when i did the swap i left the t5 in and just threw a hayes street/strip clutch kit at it. Currently im on my 3rd clutch in about 4 months, and dont say i cant drive, i had the car for 3 years prior to the swap and the stock clutch was still good when i took it out. My problem is first of all my motor eats clutches and recently ate my t5.
i do drive the car on the street but i want it to be fast as possible, i have a 355posi out of my friends ls1, but i need a trans that is both strong, and will destroy everyone i line up with. And it also has to be able to handle the supercharger in the cars future and my 100 shot of nitrious that i have already
let me know what you guys think about trans and clutch thanks
Old Jan 21, 2006 | 09:35 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default RE: What transmissions would you recomend
hmm....T-56?
Old Jan 21, 2006 | 09:37 PM
Sleeper91's Avatar
you dont sound too sure of urself
whats your reasoning
Old Jan 22, 2006 | 03:17 AM
v8chvyguy's Avatar
Check out 5speeds.com. They have a Muncie section where they sell brand new muncie M20, M21, M22's. I bet their M22 fully dressed will handle that motor. But, from what I've been told by some of my fellow forum members is that the M22 is a bit noisy.
Old Jan 22, 2006 | 04:22 PM
bjames5's Avatar
I would check out Mad Dog transmissions. They have good prices and ship to your door step. You can find them on ebay for sell as well. I got a Godfather NHRA transmission that can hold over 700hp for $1170 that came with a one year warrenty with unlimited mileage.
Old Jan 22, 2006 | 04:25 PM
Sleeper91's Avatar
An m22 sounds good, thats a 4 speed right?
One question would it bolt up. and what do I do with the tourque arm from the rear end to the trans
I would like to eliminate it or attach it some other way because ive broken two, and a bunch of thoose mounts
thanks
Old Jan 22, 2006 | 04:29 PM
Sleeper91's Avatar
Mad dog trans only does autos right?>
I want to keep the manual, alot more fun
Old Jan 22, 2006 | 04:36 PM
JD1969's Avatar
ORIGINAL: Sleeper91
thanks
Get a torque arm that mounts to the cross member, check out Spohn they have them. You can get a T56 that will hold whatever you can though at it from http://www.g-forcetransmissions.com/default.htm .. Not to pick on you but you will also need a lot more power to destroy anything you line up with
Old Apr 3, 2006 | 10:42 PM
karsinguitars's Avatar
Often it is the most fundemental things that are overlooked.
http://www.precisionmeasure.com/fixt5.htm
The above link I looked for and found because my pilot bushing is going and I just replaced it about eight months ago.
I think I could have a bellhousing alignment issue and that you could as well.
It could certainly cause you to eat some clutches
grabbem88
Jul 30, 2011 09:48 PM
jonnieboy73
Jan 21, 2009 01:38 PM
Swing_it1986
Dec 24, 2008 12:11 AM
sPaC31
Jul 23, 2008 10:01 PM
n8sz28
Aug 28, 2005 03:25 PM
