Is it ok to use synthetic trans flluid in a 700r4
Old Apr 7, 2019 | 06:13 PM
Stevolwevol's Avatar
Default Is it ok to use synthetic trans flluid in a 700r4
I'm gonna drop the pan on my transmission, and I was considering replacing the fluid with synthetic. Is this ok to use this in a 92 700r4? Any input would be appreciated.
Old Apr 7, 2019 | 09:59 PM
I would not unless you are replacing all the fluid. Remember there is a lot in the torque converter.
Old Apr 7, 2019 | 10:36 PM
No reason why you can't, synthetic fluid is 100% compatible with conventional. But if you're wanting to get the full effect of synthetic, then you would need to do a complete flush. How many miles, and does the old stuff smell burnt? If the old fluid is old, nasty and burnt smelling, don't do anything more than a drain and fill, using conventional fluid.
Old Apr 8, 2019 | 07:14 AM
I've actually done a drain and flush every summer/spring for 5 times now, but I've used conventional, not synthetic. The fluid looks good.
GoofieJ21
Aug 30, 2013 12:57 PM
Stevolwevol
16
Aug 13, 2012 06:16 PM
mrlightrail
Feb 12, 2009 08:56 PM
LingLing
82-92 V8 Tech
Apr 20, 2007 03:39 PM
microkid
Mar 31, 2007 01:11 AM
