v8 front coil springs?
Old Jun 24, 2009 | 07:07 PM
Edscamaro89's Avatar
Default v8 front coil springs?
I have been useing the v6 front coil springs since i put a 350 under the hood. the car sits low, slight rake, AS always the front nose clip will scrape ..but i know the iroc-z suspension was calibrated for the car (handeling & performance). should i put the v8 springs in?
Old Jun 25, 2009 | 08:44 AM
The V8 springs are designed for a heavier load, so they should not sag as much. Most of the handling calibrations are in the shock absorber valving, sway bar dimension, tires, stiffer springs may be included, but ride height is more of a function of spring lenghth. This means that you can have a car ride higher with softer springs, all depends on how much the spring can be compressed.
Old Jun 25, 2009 | 11:44 AM
alright thanks, didnt really know if changing them out was worth my time.
Craig Ferguson
Jan 21, 2014 11:15 AM
1augapfel
Feb 1, 2013 08:04 AM
southw2
67-69 V8 Tech
Feb 9, 2011 04:27 PM
sawyermgmy
70-81 V8 Tech
Jan 30, 2011 10:58 AM
jw333
Nov 22, 2007 11:22 PM
