91 v6 swap to 5.7 tpi
Old 10-11-2018, 08:52 PM
Tealcamaro's Avatar
Default 91 v6 swap to 5.7 tpi
Hello everyone...I am new and this is my first post..I have a 91 Camaro v6 I want to swap with a 5.7 tpi...will the v8 harness connect with the v6 harness and will the 700r4 trans bolt to the v8? ..thank you all for any help and advice!!
Old 10-15-2018, 06:52 PM
No you need a V8 harness and ECM along with a V8 transmission. You want the trans from a 350 TPI car because they are stronger then the V8 305's.
V6 trans is the wrong bolt pattern and would fail under the torque of a 350. You will also need to disable the anti theft system. I am not 100% sure what that entails but I know GM was trying to stop people from just re keying stolen cars.
Old 10-15-2018, 07:11 PM
Tealcamaro's Avatar
I have the v8 engine harness and ecu... will that v8 harness plug into the v6 body harness??
Old 10-16-2018, 07:19 PM
Sorry but I do not know what else you ECM would plug into besides the anti theft system. This is long before body control modules or in car networks like the CAN system. .
The only thing that comes to mind is the Data port and serial line to the ABS. Those would be generic.
Old 01-28-2019, 01:29 PM
I recently inherited a 89 RS with the 5.0L, trying to get it fixed up for a buddy. Is it possible to do a engine swap to the 5.7L? If so what all has to be changed on the car for the swap to work?
Old 02-05-2019, 08:14 AM
The TBI system does not have enough air flow for the 350 and the ECM is not tuned for the 350. If I remember right the TBI system is under 300CFM
drspin220
09-29-2009 12:27 AM
camarofreak
08-20-2007 02:25 AM
ShawnGP
03-05-2007 12:18 PM
dewey86
12-22-2006 09:25 PM
domino_9756
08-15-2005 11:47 PM
Quick Reply: 91 v6 swap to 5.7 tpi
