Z28/IROC Gauges into a Sport Coupe - Easy swap??
Old Aug 12, 2007 | 04:36 AM
asterix's Avatar
Default Z28/IROC Gauges into a Sport Coupe - Easy swap??
Hi there -
I've just bought an '87 sport coupe, basically cos it's got a new 350 motor in it.
Unfortunately it's still got the basic gauges, no tacho etc.
I can get a cluster from an IROC/Z28 easily, but will it plug straight up, or do I have to get senders for tacho/oil/volts and do new wiring too?
Thanks!
Old Aug 12, 2007 | 10:59 PM
zeus8807's Avatar
Default RE: Z28/IROC Gauges into a Sport Coupe - Easy swap??
its a straight swap, i had the same guages in my 87 no tach dummy lights, and i put in the 145 iroc cluster, and its a straight swap, just so you know thou you have to take off all the front plates to get to the retaining nuts that hold it on(so all you see if the white plastic and guages) and then just pop off the speedo cable, and thats all there is to it.
Old Aug 13, 2007 | 06:21 AM
asterix's Avatar
[align=left]Great, thanks for your help.....Ebay next stop!!
[/align][align=center] [/align]
slayer13x
Sep 22, 2013 05:43 PM
chevydrvr
Apr 29, 2009 10:06 PM
Kammerpal
Jan 10, 2007 12:34 AM
Andross
Nov 21, 2006 03:24 AM
