Wiring help
Old Aug 28, 2016 | 09:30 PM
KeppKepp's Avatar
Default Wiring help
Ok, I have a 86 iroc that has a carb 350. (bought it from a guy and the motor is seized) I pulled motor and trans and saw I had a wiring web. I look at other people's camaros and the deleted a lot of stuff. I just want to know what I need and what can be deleted.
(I've deleted A/c, smog, cruise cont and a few vacuums)
Old Aug 29, 2016 | 05:37 AM
Everett#2390's Avatar
Welcome Kepp.
Water temp - green wire
Alternator - red BATT stud wire and the two smaller wires, alt excite and voltage sensing,
Oil pressure sender for gauge,
Starter wires - battery cable, solenoid power and battery recharge from alt,
Cooling fan power, lights, heater blower power, horn, brake metering block for BRAKE light in case of an axle leak,
You might get a Haynes manual in helping you through
Old Aug 30, 2016 | 11:20 AM
KeppKepp's Avatar
Welcome Kepp.
Thanks for responding, so all this stuff I need? And can junk the rest?
Old Aug 30, 2016 | 11:51 AM
I wouldn't junk it until the new stuff is running.
Get the new stuff running first, then remove.
Trial & error
calcustoms
Jun 24, 2006 02:53 PM
calcustoms
Jun 23, 2006 03:56 PM
calcustoms
Jun 23, 2006 03:54 PM
calcustoms
SixReasons
Jan 11, 2006 12:46 AM
