What temp should I be running at?
Old Apr 20, 2007 | 09:15 PM
ScottD's Avatar
Default What temp should I be running at?
Well, with the 350 swap done I took her on the maiden voyage tonight. Everything looked fine, but I think shes running a bit hot. She seemed to hover in the 230-240 range. Never went higher, but its still relativly cool outside. Im running a 1977 350 with headersin a 82 Z28 if that helps any. (just mentioned the headers because Ive heard people say they make the engine run hotter)
Old Apr 21, 2007 | 01:19 AM
ScottD's Avatar
Default RE: What temp should I be running at?
Anybody?
Old Apr 21, 2007 | 02:46 AM
MadMikeZ28's Avatar
That is a little warm specialy when its cool out. Stop and go traffic behind other cars? How well is your fan working? What temp t-stat did you use? Do you have the air deflector under the car?
Old Apr 21, 2007 | 08:15 AM
ScottD's Avatar
Fan is working, some of the air dams are still missing. (Actually less restrictive this way.) Gauges: Oil is a Sunpro replacement. Temp- stock dash guage but I had to use a different sending unit. Maybe the older sending unit is calibrated a bit differently?
Old Apr 21, 2007 | 09:19 AM
Blade's Avatar
June 2007 ROTM
my stock 91RS ran 210 and would get warmer at a traffic lights.
What about running a electric fan?
Old Apr 21, 2007 | 12:57 PM
hurley870's Avatar
When I bought my 88, the air dam underneath the car was snapped off and it would run pretty hot (220-240) on a nice day (60 degrees). I haven't had a problem since I replaced that air dam, and it's been75-80 degreesaround here. It got close to 200 degrees since then but no higher. So if that is broken, you should replace it.
Old Apr 21, 2007 | 10:14 PM
MadMikeZ28's Avatar
ORIGINAL: hurley870
That is excatly right!
Gm's R&D put those there for a reason. They direct the air where its needed.
The sunpro gauges are poop! It may be new but not accurate.
Old Apr 22, 2007 | 02:02 AM
bigblockhemi's Avatar
I had the same issue with the 87 IROC 5.7, bought the air dam and it worked much better. I alsostill havea problem with the electrical fans though. What thermostat do you have?
chevboy
Feb 6, 2015 08:23 AM
Jelz28
Jul 20, 2012 11:00 PM
Mitch Upton
67-69 V8 Tech
Sep 9, 2011 04:04 PM
wantvegas
Aug 4, 2011 12:00 AM
bill12690
Sep 27, 2006 01:21 AM
