hard start at running temp.
Old Feb 5, 2015 | 02:04 PM
chevboy's Avatar
Default hard start at running temp.
I have a 96' z28 when it is cold it starts up fine but when it gets hot it hard to start acts like it not getting gas. I have replaced the fuel filter,fuel pump,spark plugs, wires and distributor. But it still doing the samething, but once it started it runs fine and have all its power. I have some 02 heads and headers on the engine could the cause a problem.
Old Feb 5, 2015 | 02:58 PM
hay chevboy welcome to the forum. i made a thread and moved your post for you. it sounds to me like your starter is failing when it gets warm/hot. have a look and see if your heat shield is still there.
Old Feb 6, 2015 | 08:11 AM
chevboy's Avatar
thanks will try that.
Old Feb 6, 2015 | 08:23 AM
This doesn't sound like you're describing a periodic dead starter (engine doesn't turn over) issue. Are you getting an "engine cranks over but no start", or a "no crank at all" (starter goes click or less)?
Jelz28
Jul 20, 2012 11:00 PM
Tommyboyink
Oct 20, 2011 12:11 PM
wantvegas
Aug 4, 2011 12:00 AM
ScottD
Apr 22, 2007 02:02 AM
bill12690
Sep 27, 2006 01:21 AM
