Weird Noise!!
Old Jun 29, 2010 | 08:27 PM
  #31
assuming that the shop will do the remove and install thats not to bad.
Old Jun 30, 2010 | 01:59 AM
  #32
ThirdGenCrazy's Avatar
yea all the junkyards i went too wanted way to much for a 700r4. And yes, they are doing the removal, build, and install for that price.
Old Jun 30, 2010 | 03:46 AM
  #33
Oh im also considering going ahead and buying a shift kit for it. Any body have any suggestions or past experiences with a certain brand?
Old Jul 1, 2010 | 07:20 PM
  #34
microkid's Avatar
March 2011 ROTM
Technical User
go with the b&m kit. they offer 2 version, the heavy duty/rv and the street strip. its up to you of which you want.
Old Jul 2, 2010 | 12:26 AM
  #35
Seal7's Avatar
Originally Posted by ScottD
Whoa....hold up. Your saying 'clutch' and 'automatic transmission' together....a 'slipping clutch' is generally the result of a worn friction/pressure plate in a manual transmission. While not a simple job, it generally doesnt require an entire new transmission.
Automatic transmissions are a whole other ball game. When an auto transmission starts slipping, it generally means the internal assemblies (bands, plates, etc) are worn beyond service and usually requires the entire transmission to be replaced.
It sound like your automatic transmission is slipping. Start hunting junkyards for a replacement.....
I hate transmissions....they are filled with stinky red cool-aid and only work by some weird magic that only transmission shops understand. Weird *** pressure modulators and doohickeys and ****. I dread the day mine dies. Thats going to be a learning experience for me. Good luck. Let us know how the replacement goes.
In regards to the tranny slipping, it dosnt necessarily mean the trany is going out, could be as simple as low fluid, check the tranny fluid and if its low you tranny will slip. If it is low, check the tranny pan and make sure u dont have a leak, and then fill it with the proper fluid.
Seal
Old Jul 2, 2010 | 06:15 PM
  #36
No leaks and it was full. Doesn't matter now, it's in the shop being rebuilt
Murda99v6
Sep 30, 2010 09:56 PM
TEXASMAN1
Jun 12, 2008 04:45 PM
biohazard
Jan 7, 2008 05:47 PM
Saint_Ali
Nov 14, 2007 12:45 PM
davidalvarez82@hotma
Oct 28, 2006 03:28 PM
