weird noise
Old Jan 1, 2008 | 03:09 PM
biohazard's Avatar
Default weird noise
Well after mother nature blasted us with 10 inches I was driving my car home from work and to avoid getting hit by a idiot with a cardboard box for a rear window I slowly hit a curb and went over it! My car is lowered 1 3/4 I didnt even think that my car would even have enough speed to get over the damn thing lol.Anyway well I was stuck on the curb and scraped my bottom pretty good from the sound.I knew my exhaust was clanking against the x brace below and it bent down a little soI jacked up my car and fixed that problem. well thena couple weeks laterI was driving and i went over some tracksandscraped again.Well afterdoing a long pissed off burnout my car makes a clunking noisewhen I first hit the gashard or punch it at low rpm's. If I take offslow it doesnt do it. It sounds like its coming from the tranny back somewhere?? I just got the car about a month ago after giving up on mustangs and dont have a clue about camaro's . I wouldnt think that it would be a driveshaft since its tucked up? so I am wondering if its a mount or u joints or a rear end? The car was running perfect before the curb so I dont know ? even after the curb it didnt do it....just started after the tracks? Any help would be a blessing!! thanks
Old Jan 1, 2008 | 03:10 PM
biohazard's Avatar
Default RE: weird noise
The car is a 96 z28 convertable
Old Jan 1, 2008 | 07:58 PM
Check transmission mount, and torque arm mount on transmission tailshaft housing.
Old Jan 3, 2008 | 11:50 PM
tmas02's Avatar
yeah check all your mounts if all good then wiggle your drive shaft to see if it feels loose then it's your u joints... if not that then more than likely rearend... might have pulled the last straw from your rear end after your "pissed off burnout" lol good luck though man
Old Jan 4, 2008 | 12:31 AM
What a coincidence, I used to have a 96 Z28 convert. When my trans mount tore apart, the tail of the trans would rise up under hard acceleration and slam against the tunnel. It could be both heardand felt, and it also left behind a few dent marks. Sounds like you may have separated the trans mount when you bottomed out. If it's bad, I recommend replacing it with a urethane one since they have an interlock and can't come apart. Not only does the trans mount have to support the trans, it also has to withstand the extreme upward force from the torque arm.
Old Jan 4, 2008 | 06:51 PM
biohazard's Avatar
Thanks!!!!...Yea that sounds just like the problem!! I can feel it around the end of the trans.I am taking it to my friends shop tommorow morning so hopefully thats it! Any advice wher to get the urethane??
Old Jan 5, 2008 | 12:35 AM
A lot of auto parts stores sell them.Auto Zone carries the Energy Suspension brand.
Old Jan 7, 2008 | 05:47 PM
biohazard's Avatar
worked on it this weekend and it was the tranny moiunt!! Fixed it and runs great again! ....also I have a little ding where it was hitting!
Murda99v6
Sep 30, 2010 09:56 PM
TEXASMAN1
Jun 12, 2008 04:45 PM
Saint_Ali
Nov 14, 2007 12:45 PM
davidalvarez82@hotma
Oct 28, 2006 03:28 PM
LS Series Tech
Sep 9, 2006 08:45 PM
