Weird Noise!!
Old Jun 27, 2010 | 10:53 PM
  #21
ThirdGenCrazy's Avatar
Sorry about that, I'm still new to all this transmission talk. I'm reading up on this TV cable right now.
Old Jun 28, 2010 | 04:51 PM
  #22
Update:
My dad may have found a TH-350 transmission, but the question is for you guys. Will everything bolt back up, and keep the same driveshaft?
Old Jun 28, 2010 | 05:25 PM
  #23
No...and no.
You're going to have to revamp the crossmember, and lengthen your driveshaft. Plus you're going to lose overdrive, which is going to hurt your gas mileage if you drive it on the highway. I'd look for another 700R4. You're certain your present one is toast then?
Old Jun 28, 2010 | 05:51 PM
  #24
Transmission shop says yes, the present one is toast. But, since of short on funds right now, I was told that it would be cheaper to rebuild a TH-350 or a TH-400. I guess the 400 wouldn't work right either?
Old Jun 28, 2010 | 06:40 PM
  #25
microkid's Avatar
March 2011 ROTM
Technical User
Hmmmmm...has your trans been wired differently from how it came from the factory? The 700R4/4L60 has always been designed to lockup once the car is loafing in 4th. Locking the t.c. clutch in a lower gear can damage the clutch since it isn't designed to take the torque of hard acceleration.
the 4l60e in my 85 blazer will lock up in third gear under two conditions. i manually select third and its over 45, or if its a forced downshift, it will then lock again around 75-80. i as well as getting a whine noise and i know my trans is slipping in 4th, but it sounds like its in the rear
as for the trans, your best bet is to get a used one for $100. the work required to rebuild and retrofit a th350 or 400 far outweighs even a rebuilt 700r4, which is equal to the 350 just with an overdrive
Old Jun 28, 2010 | 10:10 PM
  #26
ScottD's Avatar
No...and no.
Im telling you, listen to the man......not having overdrive sucks...especially if you run lower gears. Ive got a turbo 350 and 3.73's.....my top end sucks and I spin about 2800 rpm on the highway.
Old Jun 28, 2010 | 11:14 PM
  #27
I know what your saying, but if it's going to be cheaper to build a th350 or a 400, i'll have to go that that route because im really low on money.
Old Jun 29, 2010 | 06:25 PM
  #28
looks like im going to have my 700r4 rebuilt. price tag = 1,399$... Looks like there's alot of overtime at work headed my way
Old Jun 29, 2010 | 06:57 PM
  #29
ScottD's Avatar
Holy frig man. Was getting one from a junkyard even an option for you? 1400 bucks? ouch.....
Old Jun 29, 2010 | 07:11 PM
  #30
microkid's Avatar
March 2011 ROTM
Technical User
ouch. i only spent $1250 for my 4l60e from advance auto (3yr, 100k mile warrenty) and is in the process of going in
