Upgrade to G80 Rear End
Old Jun 9, 2008 | 09:52 PM
77vettejeff's Avatar
Default Upgrade to G80 Rear End
Did a search but could not find much on this. What would be involved in upgrading a standard differential to G80. I know I need the G80 carrier. Can it be installed into the standard differential housing? What about the axles? Bearings?
Old Jun 10, 2008 | 04:49 AM
blackz87's Avatar
Default RE: Upgrade to G80 Rear End
First G80 is the RPO code for Limited Slip rear. Yes a limited slip can be purchased for any rear axle assembly. But first your info is limited to the present type of rear axle, gear ratio, axle shaft spline countand year. Also this is not going to be a cheap DIY mod.
Old Jun 10, 2008 | 05:32 PM
thanks. Yes, understood, G80 is the code.
Old Jun 10, 2008 | 08:06 PM
the year is 1990 RS 305 TBI. The current rear is 2.78:1 standard. Not sure of spline count. I will check. I understand that I may have 26 or 28 spline axles, true?
So, if I have 28 spline, I should be able to get complete posi carrier assembly from a G80 7.5" or 7.625" (with bearings), get ring and pinion set,and should be able have shop do the install w/shimming?
Old Jun 11, 2008 | 05:22 AM
blackz87's Avatar
ORIGINAL: 77vettejeff
You have a 2-series 2:73 ratio 10-bolt with 28 spline axle shafts. So to change you would need a 3-series limited slip carrier, new gear set (3:42 or 3:73), 7.5/625 dia (both are the same ) and rebuild kit. You will need about $700/800 for parts and labor. Now is this going to worth it with the 170 hp305 TBI?? My opinion is NO.......money better spent elsewhere.
Old Jun 11, 2008 | 12:57 PM
Jr. Mechanic's Avatar
August 2009 ROTM
ORIGINAL: blackz87
? You could do the swap actually pretty cheap. A donor car would be the easiest, but if you just get a complete rear, springs, and sway bar, you can just swap it right in...
Old Jun 11, 2008 | 06:06 PM
Thanks for the comments. I do not know Camaro's well. It is alot of money. This is my son's car. I am really surprised that an RS Camaro did not come with a posi.
Old Jun 11, 2008 | 07:18 PM
blackz87's Avatar
The Slang term Posi is short Chevrolets name Positraction which is a Limited Slip. It was a extra cost options and I would guess that 90% of the cars on the road have a open diff.
shypes3
Aug 6, 2011 08:49 PM
bizarre660
Mar 30, 2009 07:45 PM
dwanius
Jan 6, 2008 04:02 PM
microkid
Nov 4, 2006 02:24 PM
TSTONE
Sep 24, 2006 06:56 AM
