rear end gear oil upgrade
Old Oct 31, 2006 | 08:57 AM
microkid's Avatar
March 2011 ROTM
Technical User
Default rear end gear oil upgrade
i have a posi rear end (dont know the gears in it, my brother is looking that up for me) in my 86 z28, and i want to upgrade the oil in it to some royal purple. what weight should i use. also, there is the tag that says to used limited slip oil only. is there an oil specific for limited slips?
Old Oct 31, 2006 | 10:17 AM
shnormo's Avatar
Default RE: rear end gear oil upgrade
Royal Purple 75w-90 will do you good. I believe it has a LSD formula built in. If you need more LSD oil, your local parts store should be able to supply it.
Old Oct 31, 2006 | 12:33 PM
shnormo's Avatar
http://www.royalpurple.com/prodsa/mgeara.html Yes it does have it built in.
Old Nov 4, 2006 | 02:24 PM
microkid's Avatar
March 2011 ROTM
Technical User
thanks shnormo
shypes3
Aug 6, 2011 08:49 PM
bizarre660
Mar 30, 2009 07:45 PM
77vettejeff
Jun 11, 2008 07:18 PM
dwanius
Jan 6, 2008 04:02 PM
TSTONE
Sep 24, 2006 06:56 AM
