Tranny and rear end upgrade?
Old Aug 6, 2011 | 05:27 PM
shypes3's Avatar
Question Tranny and rear end upgrade?
Hey guys, I have a 95 z that I'm doing some upgrades on. LE2 heads, cam, and possible stroker kit, just to name a few of them. I'm hoping to get around 500+ to the wheels. I know that the stock rear end is a flawed design for heavy power, and ive been having some issues with the tranny slipping, so I'm wondering which direction I should go for rear end and tranny. Is the 4l60e worth sending off to have beefed up? And is it a lot of hassle to put a 9" under it out of a ford pickup, or should I just spend the money and get a pre-fab. rear, and if so what are some good options?
Old Aug 6, 2011 | 08:39 PM
heres a couple of good trany places. performabuilt will rebuild your trany and patc sends you a trany, no core.
4l60e 700r4 4l80e performance gm ford transmission performabuilt
4L60E Performance Transmissions from PATC
heres a couple of places for rearend.
Camaro Suspension | F-Body Suspension | G-Body Suspension | Spohn Perf
Midwest Chassis & Performance
Old Aug 6, 2011 | 08:49 PM
A rear of a pick up truck is going to need a lot of machine work and fabrication to make it fit. The truck axle will have to be cut to the proper width, and all the brackets fabricated and welded to it, and most important in the precise spot.
jcastner
Jun 13, 2011 09:20 AM
bizarre660
Mar 30, 2009 07:45 PM
77vettejeff
Jun 11, 2008 07:18 PM
microkid
Nov 4, 2006 02:24 PM
TSTONE
Sep 24, 2006 06:56 AM
