Um...what valve seals do I use????
Old Dec 24, 2009 | 11:02 PM
ScottD's Avatar
Heads-175 used
head machine work- 120 to surface, 100 to cut guides=220
Cam, lifters and springs from Jegs= 275
intake manifold-125
misc gaskets-75
headbolts-30
May still need pushrods, dont know yet, havnt measured....
Im a little drunk right now and am forgetting some small items....
Time spent finding out these dont just bolt on.........priceless...
So before I post a new thread, maybe someone can tell me what the actual headbolts are tightened too?
Ive seen three steps of ft-lb torquing, and Ive seen torque and then angle.......which one do I do?
Old Dec 25, 2009 | 09:29 PM
microkid's Avatar
March 2011 ROTM
Technical User
yea, you could make a good price comparo for buying aftermarket heads vs. swapping to vortecs. and if you went to a roller cam, you will need push rods. if you are using a flat tappet, you will probably still need push rods since the heads were resurfaced and the probablity of the rocker stud being at a different height
Old Dec 26, 2009 | 10:47 AM
GRIFF's Avatar
The getto grind doesnt invollve grinding the valve guides you grind the backs of the spring retainers...
Old Dec 26, 2009 | 12:24 PM
ScottD's Avatar
There are two versions of the 'ghetto grind', one involves the guides, the other the keepers. Regardless, I opted to have the guides machined. Im tired of dikin with this project and at this point I wasted a ton of money, whats a ton more!
Old Dec 26, 2009 | 11:18 PM
GRIFF's Avatar
It sounds like you are going about it the right way so I doubt it is a waste of money. Also the Vortecs will have some decent resale value when you go to upgrade.
McGnrAcDcfan227
Sep 5, 2009 09:18 AM
buckfever
Jun 27, 2008 10:50 PM
microkid
Dec 2, 2007 11:59 AM
1995Camaro
Jan 7, 2007 11:42 PM
sewerrat
Aug 26, 2006 07:03 PM
