Turn Signals Dont Work./Hazzards Do!!HELP!!!
Old Aug 11, 2009 | 12:57 AM
chevy7590's Avatar
Default Turn Signals Dont Work./Hazzards Do!!HELP!!!
well my turn signals stopped working but the hazzards still work fine. they are out all the way around. I replaced the flasher, and the multi function lever. what can it be? I desperately need to get them working before i get a ticket plus the dream cruise is this weekend and i cant rely on hand signals in the bumper to bumper cruising. PLEASE HELP ME OUT!! thanks
1987 camaro rs. v6 173 2.8l. (s) eng. code.
Old Aug 11, 2009 | 10:59 AM
There are two flashers one for the hazards and one for the signals.
Old Aug 11, 2009 | 12:54 PM
^^^ x2 mine is just above the diagnostic plugin on the passenger side of the steering column. not sure on 3rd gen.
Old Aug 12, 2009 | 10:39 AM
chevy7590's Avatar
yea so far i could only see one flasher located in the convient access panel right under the steering wheel. if there is another flasher elsewhere on the car please let me know.
thanks
Old Aug 12, 2009 | 10:41 AM
Stix80's Avatar
did you check your fuses
Old Aug 12, 2009 | 10:51 AM
chevy7590's Avatar
yea that was the first thing i did. its wierd. hzzards work. turn signals dont. i only found one flasher so far under the steering wheel.
Old Aug 12, 2009 | 06:59 PM
microkid's Avatar
March 2011 ROTM
Technical User
the turn signal flasher should be about 8-10 inches above the four way flasher. mine went bad, but failed to the on position. i hope you have small arms and hands as its a tight fit
Old Aug 12, 2009 | 11:53 PM
chevy7590's Avatar
Any idea where the 4 way flasher or the t/s flasher is located on the car. im thinkin its behind my under dash pad. sounds bad but i can work on a motor mechanically but when it comes to electronics in the car i never really cought on hah!
Old Aug 13, 2009 | 06:35 PM
microkid's Avatar
March 2011 ROTM
Technical User
see post above yours
jharp59
Jan 25, 2011 10:25 PM
Franksflying1
Sep 7, 2009 03:46 PM
chevy7590
Aug 12, 2009 12:21 PM
1998 firebird
Jul 16, 2009 03:51 PM
3.4CamaroCDOG
14
Mar 10, 2008 04:43 PM
