Wheels, Tires and other Exterior Talk about your rims, body kits, and other exterior mods here.
turn signals dont work
Old Mar 7, 2008 | 05:07 PM
3.4CamaroCDOG's Avatar
Default turn signals dont work
neither one of my turn signals work i changed the bulbs and everything
when i took the bulb out there was some yellow stuff could this be the problem?
Old Mar 7, 2008 | 05:25 PM
age84's Avatar
March '09 ROTM
Default RE: turn signals dont work
Do your hazzards come on
Old Mar 7, 2008 | 05:41 PM
BigRandy95's Avatar
i had a loose ground on my truck that caused that to happen. just a thought
Old Mar 7, 2008 | 07:59 PM
age84's Avatar
March '09 ROTM
I have had three cars 95 nissan,2004 pontiac and a 2005 cobaltwhere the turn lever on the colum went bad and need to be replaced, not cheap by all means and i would check everything first fuses and therelay,but if you lever feels sloppy and your hazzards work i would not rule out the lever.
Old Mar 7, 2008 | 10:51 PM
my hazards blink on the dash
i click it to the left and the arrow is like froze
where are the grounds at in the trunk?
Old Mar 7, 2008 | 10:52 PM
also i use to could hit it and make them work not no more tho
i need them to work almost got ran over
Old Mar 7, 2008 | 11:15 PM
age84's Avatar
March '09 ROTM
my bet is that its in the lever mech. just replace it. you can try one out of the junkyard me personally i would just get a new one if i remember the last one i bought was about 105.00 for my pontiac. My pontiac it would lock up then after i taped it they would come back on after awhile they just quit. Dose any of your flasher come onon the exterior
Old Mar 7, 2008 | 11:35 PM
yea the front signal comes on thats y i thought it was the bulb but i changed them and it is still actin up
Old Mar 8, 2008 | 11:33 AM
Here is how the grounding is laid out for rear signal lites.
Splice S415 (Rear body harness, approx 7 cm / 2" from left backup lamp breakout)
to splice S410 (Rear body harness, approx 20 cm / 6" from left backup lamp breakout)
to pass through grommet P400 (left rear, in end gate panel)
to Black ground strap under hatch release mechanism
Old Mar 8, 2008 | 11:56 AM
blackz87's Avatar
Did you replace the flasher unit under the driver side dash a $4.00 part???
