TPI swap
Old Mar 6, 2007 | 09:14 PM
92camaroRS's Avatar
Default TPI swap
Hey guys i was considering switching my tbi to tpi. I can get a used tpi system from a friend that includes everything (upper, lower intake, injectors, fuel rails, wiring harness, computer,etc) for $250. I think thats a pretty good deal, esp. for about 20 horsepower. Well my question is how differicult is this swap going to be. I can do all the easy bolt up stuff, but what about the other stuff; and what will i have to do? Thanks.
Old Mar 6, 2007 | 09:55 PM
350rs's Avatar
March 2008 ROTM
Default RE: TPI swap
aside from the obvious mechanical stuff. Drop the tank and change the fuel pump. distributor, dont forgot about that.
if you dont buy it, let me know and i will if he will sell it for that amount to me as well!!
Old Mar 6, 2007 | 10:50 PM
92camaroRS's Avatar
well for the obvious reason of needed a higher pressure fuel pump, why would i need a new distributer?
Old Mar 7, 2007 | 12:26 AM
350rs's Avatar
March 2008 ROTM
im not 100% sure, maybe clearance. all i know is it NEEDS the correct one and the TBI one will not work...
Old Mar 7, 2007 | 01:13 AM
92camaroRS's Avatar
I've been reading up and I understand this tpi swap is a lot of work. What if instead I switched to a carb. setup. I understand I would need a carb. intake, carb., air cleaner, and a noncomputer controlled distributer, and better fuel pump; is that all i'd need? Also what would I do about the existing computer, would I just pull it out? And would this be a sensible swap, because I plan on heads and cam, and with my existing tbi the heads and cam really wouldnt give me good results? Can expect any extra horsepower from this swap? Thanks guys, just tryin to figure things out.
Old Mar 7, 2007 | 01:44 AM
350rs's Avatar
March 2008 ROTM
maybe a small horse gain, but unless you know how to dial in a carb, its a lot of hassle. i too was thinking of it and had a sweet setup lined up. costs a little over a grand to get it all i think. 1400 or so i think. you wouldnt need a better fuel pump, but a pressure regulator i believe. I was told the computer can be pulled if you do ineed go carb. so your not goin TPI anymore huh?
Old Mar 7, 2007 | 09:49 AM
92camaroRS's Avatar
Idk i just wanted to know my options.
3800_seriesII
Aug 14, 2012 07:24 AM
9434V6
Sep 8, 2011 11:51 AM
xXChipXx
Aug 1, 2010 10:39 PM
miclo88
Oct 15, 2009 07:38 PM
85z285.0
Jun 2, 2007 03:19 PM
