tpi ide problems
Old Feb 22, 2007 | 03:38 PM
rollermotor's Avatar
Default tpi ide problems
I have a 88 tpi motor in a 85 camaro,I have all of the wiring in the right place and all components and sensors are new, except for the cold start injector, thermo time switch, iac vale, and iat sensor. The engine will only run if I hold the throttle slightly open. The engine will not start on its own, and won't idle, any suggestions?
Old Feb 22, 2007 | 07:48 PM
blackz87's Avatar
Default RE: tpi ide problems
Try cleaning the IAC (idle air control)or check your TPS (thottle position sensor) and see if this improves the idle 550/650 rpms. Forget about the cold start injector & CTS (coolant temperature sensor) they are not the problem.
Old Feb 24, 2007 | 02:08 AM
Goodfella's Avatar
TPS is what i immediately think. as BLackz87 said. good call
Old Feb 24, 2007 | 01:34 PM
Yea I did remove the tps on the throttle body to clean the throttle body, and I might not have it back in its original position. The engine would idle at first though when I broke-in the cam, but I was getting a trouble code telling me the mass air flow sen. was bad so I had to unplug it so the engine would even run half-decent. I have a new sensor now and right after I put it on is when this idle problem started. I will have to check on that tps at some point, thanks for the advice.
mp734
Nov 6, 2013 11:54 AM
nmallory56
Jul 21, 2009 03:34 PM
IZZY1967RS
Jun 19, 2008 10:29 PM
jdubs1813
Nov 12, 2007 04:16 PM
Nov 11, 2007 11:56 AM
