Good Replacement Rear Ends??
Old Feb 21, 2007 | 10:26 PM
nebt3x's Avatar
Default Good Replacement Rear Ends??
I am wanting to put rear disk brakes into my 87 maro and I am wondering what would be the best to swap it with (as in what kind of car)? What have you guys used on yours and what are the pros and cons?
Old Feb 22, 2007 | 12:26 AM
85z285.0's Avatar
Default RE: Good Replacement Rear Ends??
I haven't changed mine in my 85 Z yet but I would suggest looking for a wrecked IROC or firebird GTA
Old Feb 22, 2007 | 10:37 AM
blackz87's Avatar
Try to find a 1989 BW 9-bolt with the 11.88 rotors and aluminum PBR calipers.
[IMG]local://upfiles/2696/CDBB11DA0F3545FEA86F78E02F9DF17B.jpg[/IMG]
[IMG]local://upfiles/2696/CE1F301299A54F448252C8C259CC9414.jpg[/IMG]
Old Feb 22, 2007 | 04:02 PM
nebt3x's Avatar
Just wondering man but is a BW I am guessing you mean BMW??rear end as good as a chevy rear end?? I mean to me it seems that a chevy rear end would be better but just want to know what you think or know about this
Old Feb 22, 2007 | 06:16 PM
blackz87's Avatar
ORIGINAL: nebt3x
NO IT IS NOT A BMW REAR......[sm=boosign.gif]
A Borg Warner (BW)9-Bolt is a rear used on 3rd Gen Cars from 1984-1989. It is a stronger rear then the 10-bolts. Its term used to describe the the rear axles.
Old Feb 24, 2007 | 02:11 AM
Goodfella's Avatar
the word on the street is that you could just bold up a 4th gen without ABS or TCS and itll work but will just be an inch wider on each side. Prollywould take a bit of work.just to widen your search.
Old Feb 24, 2007 | 03:12 AM
nebt3x's Avatar
So just a inch wider on each sideor one inch total?
Old Feb 24, 2007 | 09:57 AM
blackz87's Avatar
ORIGINAL: nebt3x
4th Gen rear axles are 4" wider (2" per side) then 3rd Gen rears. Also your wheels will not fit.
Old Feb 24, 2007 | 02:50 PM
nebt3x's Avatar
thanks I will not be goin that route! I will try the BW way. Does anyone know where to really look to get that? Like a junk yard or what?
overhaul2
Oct 14, 2011 10:12 PM
draggo144
82-92 V8 Tech
May 24, 2010 09:33 PM
Chappie99
Apr 22, 2007 02:29 AM
sewerrat
Sep 11, 2006 10:15 AM
dirtrider95018
Aug 7, 2006 12:33 AM
