TBI intake
Old Sep 7, 2007 | 11:38 PM
gozzy341's Avatar
Default TBI intake
i would like to get a new intake for my camaro, however it is a TBI, i heard most of the intakes for TBI are very small horsepower gains, im putting a cam in it soon so i figure while i have it apart i mine as well just put the intake in it. Id like to get an intake with 10-20 hp gain if at all possible. If someone can send me any links or sugggestions itd be appreciated
Old Sep 9, 2007 | 12:39 PM
350rs's Avatar
March 2008 ROTM
Default RE: TBI intake
are you wanting to stick with the OE TBI? Ive seen Holly makes a replacement throttle body thats a bit bigger, then youll have to get a new intake manifold too. Ive seen adapter plates to take the TBI and mount it on a standard carb manifold too. However i dont know how effective this is.
Old Sep 10, 2007 | 08:44 PM
gozzy341's Avatar
now if i were to get a bit bigger throttle body with the bigger intake, what kindof horsepower gain and money are we talkin about here
Old Sep 11, 2007 | 07:29 AM
350rs's Avatar
March 2008 ROTM
not sure, might be your 20 horse, might be more. ask holly about it, see if they have the numbers on horse increase
Old Sep 12, 2007 | 10:14 AM
rlh134's Avatar
when i had my 305 tbi, i wanted more horsepower i put a set of 97 l31 heads on it and an edlebrock intake manifold but i had the shop i took it to switch my tbi out to a demon 750 carb, much much better than the stupid tbi setup and they said it wasnt hard at all to do i could have done it myself,
im pretty much working on the 300 hp 305 build up thread and seeing if i can do it, i just ordered the cam should be done with that in a couple of days, the car is a hell of alot faster than before my buddy has a 86 ss monte carlo with a 383 stroker with all the accesories and i can keep up with him now before he just destroyed me
im also working with a 92 that only has 75k miles on it so results could be different for everyone.
Old Sep 12, 2007 | 12:11 PM
1985RS's Avatar
20 hp out of just an intake manifold is a good gain, especially since tbi manifolds arent very plentiful. however switching that tbi to a carb is simple as pie, then the mods go on forever about what you can do
Old Sep 13, 2007 | 08:18 PM
gozzy341's Avatar
Thanks guys, i'll look in that
Old Sep 14, 2007 | 11:22 PM
pigchunks's Avatar
why would you downgrade to a carb for hp gain? buy a decent dual plane intake get an adapter plate and upgrade to the holley tbi with the 2 inch ventura's instead of the 1.6 you should also switch heads for better flow do the cam and upgrade the exhaust to headers. really if your going to do one you need to do all as they work together to get the motor breathing better.
but whatever you do dont downgrade because its "easier" when really it isnt carbs are unpredictable and always need a tune depending on weather conditions so forth tbi adjust's itself to give you maximum effeciency from your intake system.
tpi is also bad without alot of modification it will only give you torque and fall flat on its face at around 4800 rpm. leaving your top end well non existant basicly
crimson09
Dec 15, 2018 07:07 AM
carid
Vendor Special Buys
Jan 20, 2015 07:08 AM
antbradley100
Mar 12, 2011 05:11 AM
tuletymeZ28
LS Series Tech
Aug 22, 2010 12:12 PM
z28rob18
Jun 22, 2009 04:40 PM
