sticking throttle cable
how do i go about lubing the throttle cable? its starting to stick and is bringing the idle up to 1100-2000, and its really annoying and unsafe
I would spray the cable, the sleeve, the out side throttle pully, cleaning out the thorttle body with some cleaner and then lubricating the points where the shaft goes from the plate to the bore. Don't go to buck wild in there, lube in the intake system...Not a great out come.
