steering wheel
Old Apr 24, 2007 | 01:30 AM
sammyrocker5150's Avatar
Default steering wheel
ok, i have a 92 rs with the airbag steering wheel, and i am wondering if any older 82-92 steering wheels will fit? and can i use the hardware from my steering wheel. also, what do i need to do to not get owned by the airbag? thanks.
Old Apr 24, 2007 | 02:03 AM
zeus8807's Avatar
Default RE: steering wheel
as far as it fitting, you may have to change the coupler that the wheel attached too, i know my sport coupe and my z28 were interchangable but you had to change that coupler, otherwise you should be able to use it, as for the air bag, disconnect the battery first and youll be fine.
Old Apr 24, 2007 | 02:26 AM
MadMikeZ28's Avatar
Won't work. The air bag column is bigger around on the outside and the shaft with the splines is different.
Old Apr 25, 2007 | 04:59 AM
1985RS's Avatar
i think you know too much about Camaro's MadMikeZ28 haha
dashing88
Aug 12, 2013 01:12 PM
BasicConcepts
Dec 3, 2011 03:00 PM
ronald66
Sep 28, 2008 10:00 PM
Conundrum
Jul 6, 2007 11:48 AM
