Starter Grinding
Old Oct 15, 2007 | 03:36 PM
podsy555's Avatar
Default Starter Grinding
I have a 91 RS that when I go to start it is grinds on the flywheel.
I pulled the shroud down the other day and saw that is has started to round the teeth on the flywheel. My friend took my starter out when we put my trans in and I didnt watch him put it back in. Is there some shims that I might be missing or could the bendex just be going bad on the starter. It doesnt do it all the time just sometimes.
Thanks in advance for the response.
Old Oct 15, 2007 | 05:56 PM
parker987654321's Avatar
Default RE: Starter Grinding
Did you take the fly wheel off when you took the tranny out if so you might have put it on backwards there is a offset on the flywheele.
Old Oct 15, 2007 | 08:23 PM
If shims were used, they need to be put back othewise the starter will not engage proerly.
Old Oct 16, 2007 | 06:36 PM
cheever1804's Avatar
Like z28Pete Stated if shims were used then put them back on, you will ruin the starter or even the flywheel. If you have a local AutoZone they can test your starter whiles if off you car for free.
Old Oct 16, 2007 | 08:36 PM
Arizona Camaro's Avatar
Fix it asap because you could crack the block if the starter is moving aroundin there
Jonathon Thomas
Apr 5, 2014 11:03 AM
BlackBerlinetta
82-92 V8 Tech
Sep 14, 2012 08:51 PM
Freshcamaro
Mar 10, 2009 11:12 PM
VanHalen
Mar 1, 2009 04:36 PM
thebandit110
Apr 19, 2007 11:33 PM
