grinding
Old Apr 18, 2007 | 11:45 PM
thebandit110's Avatar
Default grinding
my car is making a grinding noise...everytime i make a right turn...i think its the drive shaft hitting the new duel exhaust. im not sure. there is no signs of rubbing on the tires or anything. could it be a tie rod or a ball joint???
Old Apr 19, 2007 | 10:01 AM
Blade's Avatar
June 2007 ROTM
Default RE: grinding
could u give us some info.
Where does it sound like its coming from? What size tires and rims are you running? Do u only hear the noise when u are turning?
Could u please answer those questions and give us some details on anything else that we could help u figure this out.
thanks
Old Apr 19, 2007 | 11:58 AM
vampyrico's Avatar
could be as simple as you p/s pump.check the fluid in it. is it getting hard to turn the wheel. if you think its the drive shaft, check under there for any damage. do you only hear the sound when the vehicle is moving?
Old Apr 19, 2007 | 11:33 PM
car_dockter's Avatar
could be left front wheel bearing
rs657f
11
Aug 31, 2014 12:00 PM
Freshcamaro
Mar 10, 2009 11:12 PM
The Banks
Mar 2, 2009 05:05 PM
VanHalen
Mar 1, 2009 04:36 PM
6v49der
Nov 26, 2007 12:30 AM
