grinding at 55+ mph
Old Jul 23, 2014 | 06:56 AM
rs657f's Avatar
Default grinding at 55+ mph
morning
tried to search this topic but had no luck. i recently had my 2 u joints and tranny mount replaced. Now i get a griding at around 55+ mph. I want to have a little more idea of what it could be before i go back up to the shop.
thanks
Old Jul 23, 2014 | 08:29 AM
can you give a general location grinding is coming from. i would look at the new u joints first. could have messed up one of the caps/needle bearings when installed.
Old Jul 24, 2014 | 06:50 AM
rs657f's Avatar
its hard to tell, it hear the sound more than feeling it. its not super loud but its there. I feel some vibrations in driver seat. feels like it comes from the rear more. It has to be u joints. It hasnt done thins until this install. All the fluids in the diff are fresh and full
Old Jul 24, 2014 | 08:41 AM
what model are we talking about? do you have a 2 piece driveshaft?
Old Jul 25, 2014 | 05:57 AM
rs657f's Avatar
Its a 1995 z28. I think its a one piece. IM.wondering if its off balance? IM taking it to another shop tmrw to make sure before I shovel out cash to do this again
Old Jul 25, 2014 | 07:27 AM
z28s have a one piece drive shaft. if the guy did it wrong he should fix it for nothing. sometimes if you dont put the drive shaft back together the same it will vibrate. the noise is not normal for that though
Old Jul 25, 2014 | 09:26 AM
rs657f's Avatar
Had my own U joints Installed. He's trying to blame.it on my parts and deny every other problem. That's the issue with them. Not trying to have them.touch my car at the moment. Going to take it for a balance tomorrow
Old Jul 26, 2014 | 08:38 AM
rs657f's Avatar
Its a pinion bearing. Installing new u joints caused it to act up. Possibly too much torque. Rear part of shaft had a lot of play
Old Jul 26, 2014 | 03:06 PM
or the mechanic got a little to carried away on the test drive. one of the main reasons i do almost all the work on mine. most times it is cheaper to replace the whole rearend if you can find a good used one.
Old Jul 27, 2014 | 07:51 PM
rs657f's Avatar
def not a happy camper right now. I think the posi is good. Im assuming I need the spider gears and ring and pinion? Having a hard time finding an entire kit.
