Speedometer problems?
Old Sep 25, 2007 | 01:08 PM
RickRox's Avatar
Default Speedometer problems?
I got problems with my speedometer when i'm moving its always 5-10 mph faster then how fast i'm actually going, I have stock tires & rims (I Think) And also where is the speedometer gear located in the transmission or the Differentials?
Old Sep 25, 2007 | 04:33 PM
MadMikeZ28's Avatar
Default RE: Speedometer problems?
Has the rear end or tranny ever been changed? The speedo gear is in the tail shft houseing on the transmission
Old Sep 25, 2007 | 05:44 PM
RickRox's Avatar
Naw the rear end hasn't been changed I don't think so anyways, I don't think the tranny has been changed either, I heard that 5 speeds didn't come in The IROC hardtops with the 350 engine.
Old Sep 25, 2007 | 08:59 PM
MadMikeZ28's Avatar
I think the 5 speed 350 with out T tops was on the 1LE package. At least in 87 it was that way
Old Sep 25, 2007 | 09:22 PM
350rs's Avatar
March 2008 ROTM
i thought they didnt put the 5 speed behind the 350 at all?? just what ive heard..
Old Sep 25, 2007 | 09:23 PM
RickRox's Avatar
I'm not so sure, i'm just going off the ad that I bought it from it said 350 could be 305.
Old Sep 25, 2007 | 10:08 PM
MadMikeZ28's Avatar
I think it was just the 1LE race package that got the 350 with a 5 speed. Does it have any a/c or power accesories?
Old Sep 25, 2007 | 10:10 PM
RickRox's Avatar
Yeah it has A/C power windows does the power lift gate count also? lol
BTW what about my speedometer? Should I just go get it calibrated or somethin?
Old Sep 25, 2007 | 10:18 PM
MadMikeZ28's Avatar
Maybe some one added that tranny and did not swap the drive/driven gear(s) for the speedo. If you know what you rear gears are with your tire size you can find out what gears you need and check them with what you have. You would not need to count teeth because all the gears are color coded.
eglide0251
82-92 V8 Tech
Oct 8, 2013 08:22 PM
Rd Huggr 68
Dec 14, 2007 04:21 PM
sp9o3
Oct 17, 2007 05:59 AM
CamaroKid81
Apr 24, 2007 11:33 AM
pistolpete_67
Feb 23, 2007 11:52 PM
