speedo problems
Old Apr 30, 2010 | 12:02 AM
clintwood's Avatar
Default speedo problems
Hi,
Ihave a 1985 camaro z28, and 5 speed. Speedometer quit working.
I disconnected the cable down by the trans, and attached it to a drill motor, and the speedo needle moves fine. I then disconnected the
cable at the box, and also the trans, but didnot see anything really wrong.
Is the problem in the trans ?
Please help.
thanks,
clintwood
Old Apr 30, 2010 | 08:50 AM
By working the speedo with the drill, you eliminated that point up as being the problem. It's possible the clip that holds the drive gear on the output shaft of the trans has broken, letting the gear slide back away from the driven gear. If you pop out the speedo housing and gear, you should be able to see the drive gear back inside the hole. Also inspect the drive and driven gear to make sure the teeth aren't chewed up, or that the square hole where the cable fits into isn't rounded out. Your problem is with one of those things.
Old Apr 30, 2010 | 08:56 PM
clintwood's Avatar
thanks, i'll check it out.
clintwood
doug91rs
May 1, 2011 08:30 PM
moradin
Oct 19, 2010 01:40 PM
Vet76te
Apr 24, 2010 11:23 AM
ScottD
Jan 4, 2009 09:45 AM
Beanmachine7000
Jul 21, 2006 10:09 PM
