spark issues
spark issues
I just got done installing '87 TPI and can't get it to run... I put in a new harness with all new connectors, relays and fuse block. I bought this on ebay for $290 @ http://cgi.ebay.com/ebaymotors/TPI-M...item1e617eec2a
great deal!!!!!!!!! I also bought an ecm ...165 from this man in Colorado for $65. After installing this harness I was unable to get spark with engine cranking. I have a remote starter switch so I was using this to check for spark without pulling a plug, but instead using an extra spark plug on one of the plug wires pulled off a plug in the engine. No spark with ignition on and remote starter switch. I tested the distrib. for power and got 12.4 volts with the ignition turned on. I also tested the distrib. power wire with ignition turned off and no voltage... I made sure all other connectors were plugged in and unpluged the tach connector just to make sure this wasn't the problem. STILL NO SPARK!!! I check all the wires I ran for new wiring harness and fuses, all good. Then I decided to test with remote starter switch again hooked up to the battery and S termanal on starter relay. SPARK!!!!! and engine started to run for 1/2 sec then died. Could not get it to start. I went to turn off the ignition inside the truck and holy moly, the key wasn't even in it!!!! So I turned on the key and tried again, NO SPARK!!! WOW, I only get spark when the key is turned off!!!! But the distrib. is getting power with ignition on but nothing when ignition off. What gives? Please help me!!!!!!!
QUICKB4C
06-15-2009 11:52 AM
